1998 Chrysler Town and Country Engine shuts down in drive
1998 CHRYSLER TOWN AND COUNTRY
LINDAWHITAKER
  • 10 POSTS
engine shuts down when car is put into drive, but dosent do it in reverse..just replaced 2 sensors..crank alignment and cam alignment..check engine light is on..
Jul 19, 2010 at 12:20 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
If the light is on, what code are you getting from the computer?
Jul 19, 2010 at 11:56 PM
LINDAWHITAKER
  • 10 POSTS
code from computer showed p1391 camshaft or crankshaft position sensor intermittent loss..we replaced both sensors..engine still stalls when in drive
Jul 20, 2010 at 10:55 AM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Is the same engine code coming back?
Jul 20, 2010 at 10:58 PM
LINDAWHITAKER
  • 10 POSTS
dont know..we borrowed a small computerized gadget that showed that code but returned it. I suppose we need to borrow it again?
Jul 21, 2010 at 9:34 AM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Sorry about that. It would be helpful if we knew if a new code came up or it is still the old one. If it is the old one, then we need to start checking wiring. Before that, believe me, you'll want to make sure you are still looking at the same problem.
PS: The item you need is an OBD 2 scanner.
Jul 21, 2010 at 10:28 PM
LINDAWHITAKER
  • 10 POSTS
thanks for your replies..we'll see if we get the same code or another and get right back with you
Jul 21, 2010 at 11:00 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Let me know so I can better direct you.
Jul 22, 2010 at 12:48 AM
LINDAWHITAKER
  • 10 POSTS
Hi we borrowed the computerized gadget again and its showing the same codes as it did before we replaced the sensors..
Jul 25, 2010 at 3:16 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
then the problem either lies in the wiring or the PCM. Check the wiring to both the crank and cam sensors for damage, corrosion... Also, make sure the wiring harness to the PCM is tight, clean, and free of corrosion.
Jul 26, 2010 at 1:12 AM
LINDAWHITAKER
  • 10 POSTS
Can you tell me what the PCM is and where it is located?
Jul 26, 2010 at 8:26 PM
LINDAWHITAKER
  • 10 POSTS
can you tell me what the PCM is and where its located?
Jul 26, 2010 at 8:28 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
The PCM is the heart of the electronic control system. It is a Powertrain Control Module (PCM). The Powertrain Control Module (PCM) is a digital computer containing a microprocessor. The PCM recieves input signals from various switches and sensors that are referred to as PCM inputs. Based on these inputs, the PCM adjusts various engine and vehicle operations through devices that are referred to as PCM outputs. It may also control the shift functions of the electronically controlled automatic transmission. I believe yours is located behind the battery mounted to the inner fender. It will have a 40 pin connector.
Jul 27, 2010 at 12:43 AM
LINDAWHITAKER
  • 10 POSTS
We have checked everything as suggested..no corrison and everything is connected tight..
Jul 28, 2010 at 9:28 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
The last thing to do is have the PCM tested.
Jul 29, 2010 at 12:16 AM
LINDAWHITAKER
  • 10 POSTS
i would have to take it to a auto repair shop for that?
Jul 29, 2010 at 9:15 AM
LINDAWHITAKER
  • 10 POSTS
Just wanted to clarify about when the engine shuts down..if it makes a difference..
when you put it in drive, it will go about 10-15 mph and will run til it gets hot (after 15 minutes or so) then the engine shuts down..
Jul 29, 2010 at 2:12 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
I hate to say it, but you need to take it and have it diagnosed. Everything we discussed is working properly.
Jul 30, 2010 at 12:24 AM
