1997 Chrysler Town and Country
CARVERNDABO
  • 1997 CHRYSLER TOWN AND COUNTRY
1997 Chrysler Town and Country 6 cyl Front Wheel Drive Automatic
my 1997 town and country has 162000 miles runs great but sometimes it get stuck in gear and I have to pull over shut off the engine restart da engine and then its fine why is that?
Tuesday, June 2nd, 2009 AT 1:17 PM
  • 109,885 POSTS
It sounds like a bad shift solenoid. Has the check engine lght come on?
Sunday, June 7th, 2009 AT 12:56 AM
CARVERNDABO
No check engine light
Friday, June 19th, 2009 AT 5:37 PM
  • 109,885 POSTS
Without checking it, I would say there is a sensor that is causing the problem. If the trans works fine after you shut it off and restat it, it's resetting itself. You need to take it to a trans tech and have them scan the computer to see if there are codes.
Friday, June 19th, 2009 AT 5:46 PM
