I have replaced the fuel filter and the fuel pump, it will start and run for 5 sec. Then die
Tuesday, September 14th, 2010 AT 9:57 AM
WRENCHTECH
MECHANIC
Do you have a security light on or flashing when this happens?
SPONSORED LINKS
Tuesday, September 14th, 2010 AT 10:18 AM
KATO6078
MEMBER
There is a alarm set light that comes on when you turn the ignition on to start
Tuesday, September 14th, 2010 AT 11:31 PM
WRENCHTECH
MECHANIC
Yes, it appears you are having a problem with the immobilizer system. It will require a factory scan tool to be able to diagnose that properly. If you have a different key, try that.
