1995 Chrysler Town and Country water pump
FEATHER38
1995 Chrysler Town and Country 6 cyl Front Wheel Drive 125148 miles
How do you replace a water pump and where is it located?
Jul 19, 2008 at 3:37 AM
2CARPRO JACK
  • 11,533 POSTS
Depends on which engine you have. A 3.0 L is a Mitsubishi and requires the entire front of the engine be taken apart (special tool for harmonic balancer)and the timing belt removed for pump replacement. A 3.3 is a Chrysler engine and the pump is external, just remove the drive belt, pulley and unbolt it and bolt tehnew one in
Jul 20, 2008 at 1:40 AM
FEATHER38
Answer took too long and not helpful. I will not use this site again. Another site took 6 min. and was very helpful. The other site gave step by step instructions.
Jul 20, 2008 at 9:04 PM
2CARPRO JACK
  • 11,533 POSTS
For the correct engine?
Jul 21, 2008 at 12:32 AM
