Air Bag Light Stays on
CHRYSLER SEBRING
OLDECZECHO
2001 Chrysler Sebring Convertible (2.7L) auto trans- 55,000 miles. A few weeks ago the airbag light came on and stayed on permanently. 3 days ago the light went out...but it came back on within 2 hours. Now it is on permanently. What does the light signify, other than a problem in the air bag system??? Where is the connector under the dash so I can try to find any codes? Thanks
Nov 10, 2007 at 4:12 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
[quote:2ac104ea16="oldeczecho"]2001 Chrysler Sebring Convertible (2.7L) auto trans- 55,000 miles. A few weeks ago the airbag light came on and stayed on permanently. 3 days ago the light went out...but it came back on within 2 hours. Now it is on permanently. What does the light signify, other than a problem in the air bag system??? Where is the connector under the dash so I can try to find any codes? Thanks[/quote:2ac104ea16]
OBDII is the connector
u should use a scanner to pull codes
let us know
Common trouble area clock spring under driver air bag
Light on means
Air bag system will not work on case of an accident
Good luck
Nov 10, 2007 at 4:31 PM
