2007 Chrysler Sebring cooling system leak
2007 CHRYSLER SEBRING
48,300 MILES • 4 CYL • 2WD • AUTOMATIC
KENC09
Hi,I have a leak in my cooling system but I can not see any visable leaks. On the ground udner the engine will be a small amount of antifreeze. I took it to a mechanic he said it was a T-stat and control valve leak. Sense I can not see any leaks when I look at the engine this does not make sense to me. Is the T-stat and control valve not visable? I called a Chrysler parts dept. They think he ment a thermostst housing. But isn't that visable? Plus sense I brought the car back from the mechanic it shows no signs of leaking, but I do slightly smell antifreeze when I look under the hood. Can their be a leak under the engine that I can't see. Under the car is a schroud that covers everthing so I can't see anythig Thanks Ken
Aug 27, 2009 at 2:16 PM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there,
Go back to this mechanic and ask him to do a cooling system pressure test, this will locate any external coolant leaks, he should be able to show you the leak while the pressure tester is on the car.
mark (mhpautos)
Aug 27, 2009 at 8:13 PM
