2004 Chrysler Sebring oil light
TED S
  • 2004 CHRYSLER SEBRING
  • 6 CYL
  • FWD
  • 64,000 MILES
Oil light flickers as engine gets hotter at idile and when coming to a stop, then stays on constant as engine gets hotter. Noticed oil sending unit had leak, replaced oil sending unti did not cure problem. So, flushed engine and replaced with 10/30.
Problem still occurs. Noticed oil coming to top of heads but did not do oil pressure test. If oil pressure is within limits, what should the next step be?
Sunday, November 8th, 2009 AT 7:07 PM
BMRFIXIT
  • 19,053 POSTS
Had many issues with after market oil pressure senders on Chrysler product for what ever reason
and after hour of testing a ten dollars unit from the dealer fixed the problem
try and get an oil pressure switch from your local dealer
Sunday, November 8th, 2009 AT 7:29 PM
