2004 Chrysler Sebring Engine sound
113,000 MILES • 4 CYL • 2WD • AUTOMATIC
MOQUE
I got an oil change and radiator flush today and when the mechanic was almost done with the flush he started the car before he replaced the radiator cap, and the coolant squirted everywhere, he shut the car off and replaced the cap and started the car back up but my car sounded way louder than normal. Now when I turn the ac off it gets louder, then when I turn the ac on it gets quieter and sounds more like the way my car sounded before I took it in. The loud sound that I am talking about is that it sounds as if the gas pedal is being pressed constantly even if the car is just parked and idle. What miight this be caused by?
Sep 25, 2008 at 11:09 AM
WILLYELENA
I have that same problem you might want to get your air compressor checked out the same thing happened as you exactly described it an now I am paying 1,200 dollars to have it fixed you should at least have it checked.
Oct 1, 2008 at 1:48 PM
