2004 Chrysler Sebring engine misfire
LUCIANDX
  • 2004 CHRYSLER SEBRING
  • 6 CYL
  • FWD
  • 27,000 MILES
I have a error code p0306 and was wondering if this is a problem that I can fix myself. It is a misfire on number 6 cylinder
Wednesday, February 13th, 2008 AT 7:48 PM
BLACKOP555
  • 10,371 POSTS
Yes you can fix it yourself, switch the spark plug and its accessories, wires etc with spark plug #1 and see if the code changes to a missfire on #1 if it does, then you have found what needs to be replaced, if not you should check the fuel injector with a scope and hear if it buzzes.
Wednesday, February 13th, 2008 AT 8:21 PM
