2001 Chrysler Sebring Oil Light
GRUNTPIG
  • 2001 CHRYSLER SEBRING
  • 4 CYL
  • FWD
  • 11,400 MILES
My oil light is coming on when my car is sitting at a stop light or in park. There is oil in the car and the light is not on when the car is moving. The light goes off as soon as you mash the accelerator. Any thoughts?
Wednesday, February 25th, 2009 AT 3:42 PM
  • 31,937 POSTS
Hi there,
This may just be a faulty oil pressure sender, get the oil pressure tested with a mechanical gauge as this will give you a true indication as to the engine oil pressure, if pressure is OK replace the sender, if oil pressure is low, post readings for more help, start here.
Mark (mhpautos)
Wednesday, February 25th, 2009 AT 3:47 PM
