2000 Chrysler Sebring Help!
KRISSYIZBORED
  • 2000 CHRYSLER SEBRING
  • 6 CYL
  • FWD
  • 132,000 MILES
I took my car to an auto store and had them hook it up because of the check engine light. My car wasnt shifting into 2nd gear, the computer said it was the shift solenoid. I got the part changed, now my car wont even go in any gear but it did fine before, but now im leaking fluid bad. Could that be the reason why? Is this something so simple I just dont know?
Thanks!
Saturday, May 22nd, 2010 AT 10:44 AM
  • 31,937 POSTS
Hi there,
You may have disturbed something when you did this repair, do you have enough oil in the system with this leak, did you fit a new pan gasket? This should have been replaced if you did not do so.
Mark (mhpautos)
Saturday, May 22nd, 2010 AT 11:04 AM
KRISSYIZBORED
So I need to go out and buy a new pan gasket? That should work for the leaking right? Would that have anything to do with it not going into any gear? Like I said it was fine before, I could drive it and everything it just wasnt coming out of 2nd gear.
Saturday, May 22nd, 2010 AT 11:14 AM
  • 31,937 POSTS
You need to check your work to make sure that nothing has been disturbed, if it was OK before you touched it then it will be low oil or something disturbed when you did the job, look carefully you may see something loose.
Mark
Saturday, May 22nd, 2010 AT 11:18 AM
KRISSYIZBORED
Okay thanks a bunch!
Saturday, May 22nd, 2010 AT 11:19 AM
