1996 Chrysler Sebring Engine redlines immediately when star
107,000 MILES • 6 CYL • FWD • AUTOMATIC
PACKRAT98
I swapped 2.5l engine and transmission from a 1997 Cirrus to a 1996 Sebring convertible. They were both running properly when I removed them. When I try to start the Sebring now the engine immediately takes off toward redline. I shut it off immediately to avoid damage. I checked throttle linkage, changed throttle body, changed computer, and it still does it. I can disconnect the throttle body and it still does it. Any ideas?
Sep 5, 2009 at 7:13 AM
KHLOW2008
  • 41,812 POSTS
Hi packrat98,
Try closing the throttle body opening and see if the problem occurs when starting. The only possibility I can thinnk of is excessive vacumn leakage into the manifold. By closing the throttle opening and if the problem still occurs, it would eliminate the throttle body and confirm a vacum leakage.
Sep 9, 2009 at 3:58 AM
