2005 Chrysler PT Cruiser PT Cruiser 2005 convertible
MARGEE
  • 2005 CHRYSLER PT CRUISER
  • 4 CYL
  • 44,000 MILES
Three weeks ago, I parked the car on an incline
driveway overnight. The temperature fell to about
20 degrees. In the morning, I put the car in Reverse and pressed the gas, the engine ran, but the car didn't move (as if it was still in park or neutral). The car jerked and then the car moved. I backed out of the driveway, put it in Drive and had the same result.
I was on vacation, so the next part of my trip was in warm weather and flat parking surfaces, and the car was fine.
Going home, I again parked cold and inclined and had the above result twice. I got home, and it has been cold at night, but the car is parked on a flat surface, and it is still hesitating, until it gets warmed up.
Once going, the car runs fine.
Can you suggest a possible problem?
Sunday, March 15th, 2009 AT 3:02 PM
  • 109,885 POSTS
Because of the position and temps, the fluid may have been slow in getting to its destination. You may want to have the trans serviced with a new filter and make sure they use the correct type of fluid. I believe it is ATF+4 but look at the dip stick to confirm.
Thursday, March 19th, 2009 AT 10:48 AM
