2004 Chrysler PT Cruiser Oil Pressure indicator light
65,000 MILES • 4 CYL • 2WD • AUTOMATIC
WOODYDEV
The oil light on my PT comes on about 1200 rpm. There is the correct amount of oil in the car, there does not seem to be anything other than the light comming on to indicate a problem.
Jan 16, 2010 at 4:34 AM
CARADIODOC
  • 34,413 POSTS
Do you have a gauge too? If so, and if it reads normally, suspect a defective sending unit.
caradiodoc
Jan 17, 2010 at 12:54 AM
WOODYDEV
Do not have a gauge; wondering if there was a warning indicator concerning oil changes. Will have approximately 4200 miles on current oil at this scheduled change.
Jan 17, 2010 at 11:23 AM
CARADIODOC
  • 34,413 POSTS
Based on the symptoms, I'd suggest having the pressure checked with a mechanical gauge. If you don't have a dash gauge, you probably don't have an oil change reminder light either. Those are only found in a few car models. Extended mileage between oil changes won't make the warning light come on either.
Engine mechanical problems will usually result in lower oil pressure at idle. Speeding up the engine increases the output volume and pressure of a worn oil pump. Low pressure due to worn bearings will also show up at idle. The fact that the warning light comes on at 1200 rpm suggests a problem with the spring-loaded diaphragm in the sending unit. That's why the pressure should be checked first with a mechanical gauge, so you'll know exactly what you have.
caradiodoc
Jan 17, 2010 at 3:48 PM
