Changing the fuel filter
RUVAKAY
  • 2005 CHRYSLER PT CRUISER
  • 4 CYL
  • FWD
  • 90,000 MILES
My car is acting like there is a problem with the fuel filter. Where is it and can I change it? If so How?
Wednesday, October 13th, 2010 AT 9:54 AM
JDL
  • 16,098 POSTS
The fuel filter, is not serviceable, shows to be part of the fuel pump module. Here is a guide to help
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Wednesday, October 13th, 2010 AT 10:00 AM
RLEACH6
  • 6 POSTS
  • 2003 CHRYSLER PT CRUISER
  • 199,361 MILES
How do I change the fuel filter on my 2003 chrysler pt cruiser. Where is it located at and why dont they sale just a fuel filter?
Tuesday, April 2nd, 2019 AT 7:31 PM (Merged)
  • 109,936 POSTS
The fuel filter is part of the fuel pump to replace it you must drop the tank and remove the fuel pump here is a guide to help you see what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Cheers
RLEACH6
  • 6 POSTS
They are saying that there is no secondary fuel filter on my car.
CARADIODOC
  • 33,967 POSTS
Nope that is the only one this car has which is normal for many cars build past 2000
2CP-ARCHIVES
  • 4,540 POSTS
  • 2002 CHRYSLER PT CRUISER
  • 55,000 MILES
How do you replace the fuel filter?
JDL
  • 16,098 POSTS
The fuel filter mounts inside the fuel pump module. Is non serviceable part. Have to replace the fuel pump module, according to my info.
S.BOONE
  • 2004 CHRYSLER PT CRUISER
Engine Performance problem
2004 Chrysler PT Cruiser 4 cyl Two Wheel Drive Automatic? Miles
How do you change the fuel filter on an 04 Chrysler PT Cruiser?
SERVICE WRITER
  • 9,123 POSTS
You don't change it as maintainence. It is part of the fuel pump module. Very pricy and very questionable when it comes to design.
https://www.2carpros.com/forum/automotive_pictures/30961_afupu_1.jpg
It is located in the fuel tank.
SCOTTNDANIELLE
  • 13 POSTS
  • 4 CYL
  • FWD
  • 95,000 MILES
2005 pt criuser fuel pump is working but no gas to motor
SCOTTNDANIELLE
  • 13 POSTS
Droped gas tank turned key and it sounds like it is suckin air or something but not in lines and can not find any holes or tears
(sorry wanted to add that info)
  • 31,937 POSTS
Remove fuel filter and test pressure, no flow faulty pick up or crushed fuel line, flow at filter check system up stream for faults.
SCOTTNDANIELLE
  • 13 POSTS
Thank you I have dropped the gas tank and the fuel pump is working pulled the codes and got p 0340 said it was the camshaft positioning sensor replaced that and still no luck read online that it could be the timing belt it is getting fire don't know where to go from here. Anybody have any suggestions.
