HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chrysler
PT Cruiser
Engine
Symptoms
Misfire
2003 Chrysler PT Cruiser causes of multiple misfire detecte
LADEEJME
MEMBER
2003 CHRYSLER PT CRUISER
4 CYL
2WD
MANUAL
106,462 MILES
What is the cause of misfire detected in multiple cylinders
Wednesday, August 25th, 2010 AT 8:32 AM
ERNEST CLARK
MECHANIC
This is most likely a bad coil pack. It can also be a failing crank/cam sensor or something as simple as bad spark plugs/wires.
DO NOT replace components without having them thoroughly tested first. Or you'll spend way more money than you have to.
SPONSORED LINKS
Friday, September 17th, 2010 AT 7:12 AM
Please
login
or
register
to post a reply.
Related Engine Misfire Content
2003 Chrysler Pt Cruiser Misfireing
Hi, I Replaced Spark Plugs And Iut Went Crazy. No Cd Player, Yet Radio Works. Then The Reading Was Wires And Coil Pack So I Replaced Them....
Asked by
chopvolpe
1 ANSWER
2003
CHRYSLER PT CRUISER
VIDEO
Intermittent Misfire
Instructional repair video
GUIDE
Misfire Random Code P0300
The world of automotive diagnostics can be complex, with numerous codes and potential issues to keep track of. One of the more common engine diagnostic codes is P0300, which...
Random Misfire
2004 Pt Cruiser Turbo-71,000 Miles. Engine Light Blinks And Car Runs Rough When The Light Blinks While Idling. Checked By Mechanic- Code...
Asked by
rhartvig
1 ANSWER
2004
CHRYSLER PT CRUISER
2005 Chrysler Pt Cruiser My Car Jerks
Hello. My Car Has Been Acting Up In The Past Few Months. The Car Jerks And Kinda Putters After It Has Been Driven For A While. At First The...
Asked by
carsrmysteries
2005
CHRYSLER PT CRUISER
2004 Chrysler Pt Cruiser Miss Fire
Th Smog Shop Says Im Having Code P2302 Problem. I Did A Compression Check All Cylinders R Pound Different N Them. Number 1 Is Not Firing. I...
Asked by
crazymann
2004
CHRYSLER PT CRUISER
2005 Chrysler Pt Cruiser Miss Fire Number 1 Sealender
Ideal Rough Back Fires Kirks Schemers
Asked by
1 steve richmond666
2005
CHRYSLER PT CRUISER
VIEW MORE
SPONSORED LINKS
Online car repair manuals
