2002 Chrysler PT Cruiser fluid
85,000 MILES • 4 CYL • 2WD • AUTOMATIC
STEFIN
where do I pour transmission fluid. I cannot find it. I find water, brake, coolant, steering but no transmission fluid.
Dec 4, 2008 at 1:26 PM
  • 110,246 POSTS
Hi:
I assume it has an automatic trans. Trans fluid is added directly into the trans dip stick tube. It's the tube that holds the dip stick. You will need a small funnel and make sure that it can get air between the tube and the funnel otherwise it will burp it back up.
Let me know if this helps.
Dec 9, 2008 at 5:44 AM
