2002 Chrysler PT Cruiser Codes
197,000 MILES • 4 CYL • FWD • AUTOMATIC
SHANE K HENDERSON
Hi
My cruiser shows the following codes
1684
0340
0500
0351
0352
1391
Oct 11, 2009 at 6:31 PM
DOCFIXIT
  • 18,828 POSTS
What are vehicles symptoms? codes maybe in history suggest have them erased then drive see what resets.
Oct 12, 2009 at 8:32 AM
SHANE K HENDERSON
Hi
How does one erase and reset codes on PT Cruiser
Oct 12, 2009 at 11:12 PM
DOCFIXIT
  • 18,828 POSTS
if the code reader you used does not have erase capabilities then go to an Auto Zone have them read and erase.
Oct 13, 2009 at 6:37 AM
SHANE K HENDERSON
HI
Yet after another opinion, from aother dealer. Their opinion is that my PT needs it's exhaust catalitic converter replaced. They say code P0351 &2 -faulty coil- would show because my exhaust catalitic converter is blocked.
I phoned a local exhaust specialist and according to them I could have the converter removed and install a normal box.
Could you please advise
Thanks
Shane
Oct 14, 2009 at 2:49 AM
DOCFIXIT
  • 18,828 POSTS
Does car run? if CAT blocked engine would not develope power. Codes do not indicate CAT failure.
Oct 14, 2009 at 3:23 AM
