2001 Chrysler PT Cruiser OVERHEATING WHEN AC IS ON.
TONY B.2601
MEMBER
2001 CHRYSLER PT CRUISER
Air Conditioning problem
2001 Chrysler PT Cruiser 4 cyl Front Wheel Drive Automatic
CRUISER OVERHEATS ONLY WHEN AC IS ON. REPLACED FAN. CLEANED RADIATOR AND CONDINCER COIL. WILL COOL DOWN WHEN YOU TURN AC OFF. Chrysler sucks!
Sunday, August 9th, 2009 AT 11:09 AM
MECHANIC
Does it overheat with the AC on at highway speeds? Also, I will assume the fan is working since it was replaced. Did you replace the thermostat?
Saturday, August 15th, 2009 AT 10:04 PM
TONY B.2601
MEMBER
YES IT OVERHEATS AT HIGHWAY SPEEDS BUT WILL COOL DOWN FAST IF YOU TURN OFF AC. YES REPLACED THERMOSTAT TO. DOES NOT LOSE WATER. BUT DEFINITLY GETING HOT. WATER PUMP IS WORKING TO.
Sunday, August 16th, 2009 AT 8:32 AM
MECHANIC
Does one of the fan's come on when you are using the AC?
Sunday, August 16th, 2009 AT 8:07 PM
TONY B.2601
MEMBER
YES THE FAN IS WORKING!
Monday, August 17th, 2009 AT 8:02 AM
MECHANIC
If the radiator is clean and not partially plugged, my next step would be check engine compression in case there is a head gasket problem, and I would also check the timing. If the belt is worn, it could have an affect on temp.
Monday, August 17th, 2009 AT 9:43 PM
DEERSNIPER27
MEMBER
1 POST
Your sending this person in the wrong direction. The answer is the cooling fan! It will no work properly on either high or low speed. My wife has the same car and did the same thing and the shop told her this and that was the problem. I tested the fan, replaced and don't have the problem anymore.
