2001 Chrysler PT Cruiser
I have a 2001 PT Cruiser and yesterday (12/31/09) the battery light came and would not go off, I then took the car to Walmart to get a new battery, however along the way to Walmart the Malfunction Indicator Light and the ABS light came on and would not go off.
Once I had the battery replaced the battery light and the Malfunction Light would not go off. I was told by Walmart it was probably the Alternator or the Starter?
In the owners manuel there were a few suggestions as to reset the Malfunction Indicator Light, as I was driving the car today the Malfunction Indicator Light and the battery light would not go off and the ABS light came on, however this light (ABS) did go off.
Can I fix this problem myself?
Thank you Lisa Pie
Thank you Lisa Pie
Jan 1, 2010 at 5:57 AM
