No heat from blower
57,000 MILES • 6 CYL • AWD • AUTOMATIC
DSNIVELY
My blower fan is working properly, my mode seems stuck on blowing air from dash vents (when I select the mode for foot level and defrost level it remains blowing from the dash vents). However, the biggest problem is that the air from the vents is outdoor temperature rather than from the engine. What is it and is something I can fix? By the way, I have checked my coolant level and checked the fuses.
Thank you - Dan
Jan 4, 2009 at 5:25 AM
IMPALASS
  • 3,112 POSTS
Hello Dan
So if I understand you correctly……fan motor speed is okay…….
The air only comes out of the front dash vents…….no matter what is selected…….
Does the AC work okay? When you select the recirculation button does it work…..come out the different vents?
For the heat……do you have any heat at all even out the dash vents……
You don’t have any heat………..
Please check your heater hoses going into the firewall…..is one hot and one not really or are they both hot or what are they?
What type of coolant are you using?
Please go to Auto Zone (AZ) or O’Reilly’s (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don’t get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery and alternator.
Jan 4, 2009 at 6:28 AM
EAGLEHUNTERS
Heater problem 6 cyl All Wheel Drive Automatic 110k miles
HI. My Pacifica climate control ON / OFF Sw and blower fan speed control do not work and when i start the vehicle,blower moter runs with full speed without selecting the ON mode.I also notice one more thing few times that,when i Sw Off the engine,blower motor runs for few seconds.
Please advice.
Thanks.
Ejaz Khan.
Dec 17, 2017 at 4:58 AM (Merged)
  • 55,616 POSTS
Hi, have you check all the fuses?
CADC4D
my pacifica 2004 american.with heater turn off the blower motor run at full speed and even on at fan lowest setting it still run on high fan could it be the control panel at fault
  • 55,616 POSTS
It sounds more like the speed control for the blower motor had gone out. Here is a diagrams to show you the location.
Check out the diagrams (Below)
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
RONOUTSR
heater blows luke warm air when moving. have had blower checked, radiator change, thermostat changed
and heater core changed. each time its worked on the heater works fine for a short period then only blows luke warm air when car is moving. xcan u help ???
WRENCHTECH
  • 20,760 POSTS
With the engine at full operating temp, locate the 2 heater hoses where they go into the firewall and feel them to see if they are both hot to the touch. If they are both hot, the heat in that vehicle is controlled by a blend door that regulates heated air flow. it is operated by an electric motor/actuator. The problem can be that the actuator is stripped or inoperative or the door itself could be damaged. This is what needs to be determined by examining the actuator and see if it is responding to heat change commands or not.
LAURAMCCABE1
Front heater not blowing in 04 pacifica. Checked the fuses and relays. They are fine. Back heater blowing cold air.
  • 75,988 POSTS
Check and test fuse no.42 40amp, front blower motor relay and the front blower power module
CHRIS ROSE
My car heat has been acting crazy. First, I turn it on and it does nothing, then five mintues later it comes on. Then maybe it won't shut off. Sometimes the front blowers blow hot but the back seat blows cold. Sometimes it does not work at all. Other times the blowers up top for the defrost work fine but the blowers for the passengers does nothing. It basically seems to have a mind of its own.....any ideas?
Feb 8, 2019 at 11:57 AM (Merged)
  • 75,988 POSTS
Get the integrated power module tested
