2004 Chrysler Pacifica HeadLamps
50,000 MILES • 6 CYL • AWD • AUTOMATIC
CJM722
Is there an easier way to change the headlights on the Pacifica other than having to remove all these parts to get to the bulb? It seams there should be a screw or something that allows the headlamp assembly to come out forward allowing access.
Thanks for any help you can give.
Jan 22, 2009 at 11:12 AM
  • 110,248 POSTS
Access is gained from under the hood.
Mar 18, 2009 at 5:44 AM
ABIBBO
unscrew the two philips head screws on top of the head light and slide the light foward out of its slot. the whole head light will come out. when putting in line up the lower tab and give a push till it clicks in. replace screws and the head light is all ready aligned
Jun 11, 2009 at 2:53 AM
