2006 Van 87 Octane Fuel
1987 CHRYSLER
JOEKAT
I have an ongoing discussion over 87, 89, HTest gas and my knowledge is that 87 is a dirty gas that can clog up your engine, that 89 is a clean more economical gas that will not clog as bad and that High test is something to switch on and off of monthly or every few fill ups or so and stay away from 87 totally to keep your engine cleaner
What do you all think or know? thanks
May 29, 2006 at 12:01 PM
VANDRAGON
  • 298 POSTS
no it is not dirty gas. most newer cars will run fine on it. only the older V8 motors don't run as good. with the price of fuel some of stations here in the south are dumping water in the tanks. i don't know what is happening to your car but it could be a clogged fuel filter or injectors.
May 30, 2006 at 2:58 AM
JOEKAT
in response to two answers:
its my girls Van 3.8L V6 2006 FWD and the book says to use regular gas and it won't be a problem, she always drove V8 before this car and insists that 87 is crappy gas and that 89 or better octane is the best and heard this years ago, that is why cars will ping and choke up on 87, she uses 89 and once in a while uses Htest to clear cobwebs she says. i say 87 is not cloggin up cars/trucks
thanx
May 30, 2006 at 4:40 AM
SDALTON19
  • 87 POSTS
octane when added or subtracted from fuel either increases or decreases the compression it ignities best at thats all the octane rating is for for example if you drive a vehicle with a high compression engine (some foriegn cars and sports cars) these engines would require a higher octane of fuel like 89 90 all the way up to 93 the fuel is just as clean (as whatever manufacturer makes it) whether you use 87 or 93 another example of this is if you have ever been to the dragstrip in your area they sell 110 octane at the pump because most race engines are stroked for higher compression low octane fuels sometimes wont even burn at all in these cars. if your car is running poorly on 87 then more than likely you just need to change your gas station. actually running higher octane fuel in a low compression engine would make it have less fuel economy and cause more carbon build up on piston heads which would increase compression but decrease volume inside the piston chamber and ultimatley shorten the life of piston rings and catylitic convertors.
May 31, 2006 at 5:06 PM
Suggested Repair
Use the regular octane the owner's manual specifies. Octane rating is not a cleanliness rating; higher octane in a low-compression engine can reduce economy and increase carbon buildup. If the van runs poorly on 87, try another station and check the fuel filter and injectors.
Conversation Summary
The owner asked whether 87 octane is dirty fuel that clogs engines and whether 89 or high-test should be used instead. Experts said octane only matches ignition to compression and does not make fuel cleaner or dirtier. For a 2006 3.8L V6 van whose manual calls for regular, 87 is appropriate; higher octane can hurt economy and increase carbon. Poor running is more likely a station fuel issue, clogged filter, or injectors.
