2001 Dodge P0720 Speed Sensor Fault
1972 CHRYSLER
WHEELS297
I have an 2001 dodge 3/4 ton quad cab 360 magnum, and a dtc po720 has came up, should I go ahead and replace the speed sensor or should I look further for a problem because the definition is actually a output speed sensor circuit malfuntion? also would this cause the truck to act like the tranny is slipping?at highway speeds(60mph) I notice a slight spike in the rpm's
Jan 16, 2006 at 3:15 PM
2CARPRO JACK
  • 11,533 POSTS
It could. There are 2 speed sensors in that. I usually replace them as a set. Ther are no code definitions to distinguish a problem between the two
Jan 18, 2006 at 8:40 AM
Suggested Repair
Replace both speed sensors as a set. The code does not identify which of the two sensors is faulty, and a bad sensor can cause the RPM spike that feels like transmission slip at highway speed.
Conversation Summary
The owner of a 2001 Dodge 3/4-ton Quad Cab with a 360 Magnum reported code P0720, described as an output speed sensor circuit malfunction, and asked whether to replace the speed sensor or investigate further. They also asked if it could make the transmission seem to slip, noting a slight RPM spike around 60 mph. The expert said it could, noted there are two speed sensors, and recommended replacing them as a set because the code does not distinguish between them.
