Cricket noises
CHRYSLER
SHYDE7
When I take off from a dead start and go slow I hear alot of squeaking from below and as I go faster it sounds like crickets chirpping. I noticed it is coming from the drive shaft in the middle of the truck. I replaced the fluid in the transfer case and I only got out 10oz of fluid. i put back at least 20oz before it started weeping out of the filler hole? Is it a possible bad bearing?
May 18, 2006 at 7:12 AM
  • CERTIFIED EXPERT
  • 53,872 POSTS
It sounds like you have u joints that need replacing
Jun 7, 2006 at 11:14 AM
