Chrysler Ticking Noise and ABS Light
CHRYSLER
GEORGIEGIRL296
There is a "ticking" coming from my car, sounds just like when a rock is stuck in the tire, someone told me it may be my front differential, something about barrings and oil...I know nothing about cars except when I put gas in them they go.. please help, as I cannot afford to take it somewhere where they can take it all apart and want to fix things that dont need fixin! also, my ABS light is on.
May 2, 2006 at 12:13 AM
MICKEY-D
  • 304 POSTS
It sounds to me like a CV joint,(constant velocity joint). This is not a job for the non mechanically inclined. The smartest thing to do, is determine which side the noise is coming from, and then purchase the complete axle assembly from a parts house, then have a shop install it for you. Good luck, let me know how you make out.
mickey-d
Dec 5, 2009 at 3:43 AM
Suggested Repair
The ticking is more consistent with a failing CV joint than a front differential. Identify which side the noise comes from, buy a complete axle assembly, and have a shop install it rather than attempting the repair yourself.
Conversation Summary
The owner of a Chrysler reports a ticking noise like a rock stuck in a tire, was told it might be the front differential, bearings, or oil, and also has an ABS light on. The expert says the noise sounds like a CV joint, which is not a job for someone without mechanical experience. They recommend finding which side the noise comes from, purchasing a complete axle assembly, and having a shop install it.
