1999 Other Chrysler Models alarm
1999 CHRYSLER
1,045 MILES • 6 CYL • FWD • AUTOMATIC
SMORALES
safety switch will not allow car to stay on. What can I try?
Feb 12, 2010 at 6:43 AM
CARADIODOC
  • 34,381 POSTS
If you mean the anti-theft system is preventing the engine from running more than two seconds each time you start it, the system is turned off by unlocking the door with the key. If that doesn't work, the switch in the door could be disconnected or a wire could be broken between the door hinges. In that case, try unlocking the passenger door with the key.
caradiodoc
Feb 14, 2010 at 9:20 PM
