1984 Other Chrysler Models daytonturbo
1984 CHRYSLER
JUTTER
Engine Performance problem
1984 Other Chrysler Models Front Wheel Drive Automatic 60,000 miles
under normal acceleration,the car runs fine but under
moderate to high accelaeration or climbing a hill, the vaccum boost goes into red zone. My mechanic has checked it with his diagnostic tester and it reads code 46 but gives no indication of what is wrong or the fix.
Any ideas
May 25, 2008 at 10:20 AM
  • 110,240 POSTS
Hi:
I looked up code 46 and it is related to the MAP sensor. Check it for a bad connection or other obvesious problems. If non detected, have the sensor's performance checked. If it's bad, replace the sensor.
Oct 13, 2008 at 2:31 PM
