1995 Chrysler New Yorker engine code 43
1995 CHRYSLER NEW YORKER
230,000 MILES • 6 CYL • FWD • AUTOMATIC
TKASLER
i recently replaced the water pump and now the engine runs rough and when i check the code i get a code 43 on the check engine light codes. it runs rougher when i accelerate. could it be a little out of time?
Dec 2, 2008 at 5:31 AM
  • 110,244 POSTS
Code 43 is a misfire. Make sure you didn't forget to replace vacuum hoses, electrical plugs, and if you removed the spark plug wires, make sure they are in the correct order.
Mar 18, 2009 at 2:09 AM
