1994 Chrysler New Yorker seat belt drivers side
1994 CHRYSLER NEW YORKER
195,021 MILES • 6 CYL • FWD • AUTOMATIC
BJWRIDER
The seat belt does not retract....however if I remove the cover and pull extra belt upward, I can get normal retraction. But when I release the belt and it retracts, it becomes lock. I then have a loose seat belt. I must again pull belt up from the roll up spindle to get it to fasten; when I release the belt it retracts but locks again.
Oct 29, 2009 at 2:44 AM
  • 110,244 POSTS
Because this is a safety issue, I recommend replacing the unit. You should be able to find one cheap in a salvage yard. Honestly, there is really nothing serviceable. Replace it with a good one that you know will work if needed.
Dec 19, 2009 at 4:23 PM
