1993 Chrysler New Yorker Fan belt slip off
1993 CHRYSLER NEW YORKER
140,000 MILES • 6 CYL • FWD • AUTOMATIC
URBANRICH7133
How can determine if the self adjusting pulley need to be replaced
Sep 14, 2009 at 2:17 AM
  • 110,244 POSTS
The belt should be tight enough that you can move it up and down aprox 3/4". Also, if you are having problems with this in wet conditions, make sure the plastic shield under the car that protects the belts is in position and not damaged. Finally, make sure all pulleys are aligned.
Let me know what you find.
Dec 19, 2009 at 4:43 PM
