1986 Chrysler New Yorker
DAVEGRAD
  • 1986 CHRYSLER NEW YORKER
Transmission problem
1986 Chrysler New Yorker 4 cyl Two Wheel Drive Automatic
I have replaced several driver side seals and they only last a few miles and then they leak again. I have been told that it could be the vent pipe but I can not locate it. Can you tell me where it is located and how to replace it?
Thursday, July 8th, 2010 AT 2:01 PM
DOCFIXIT
  • 18,828 POSTS
Seals for what?
Thursday, July 8th, 2010 AT 2:10 PM
DAVEGRAD
That would be the driverside transanxle seal.
Thursday, July 8th, 2010 AT 5:16 PM
DOCFIXIT
  • 18,828 POSTS
No vent tube what's happening is differential output bearing worn allowing axle to move in eliptical patteren taking out seal lip to axle fit and fluid comes out.
Friday, July 9th, 2010 AT 1:36 PM
DAVEGRAD
Thank you going to try that because I have tried everything else. I even replaced the CV joint.
Saturday, July 10th, 2010 AT 2:34 PM
DAVEGRAD
Could you tell me the removal and installation of the differential ourtput bearing?
Sunday, July 11th, 2010 AT 2:33 PM
DOCFIXIT
  • 18,828 POSTS
Well here is the rub transaxle assembly needs to be removed
Monday, July 12th, 2010 AT 2:27 PM
