ABS And Trac Off Lights on
JLEIGHT
1997 Chrysler LHS 3.5L 115,000 Miles ABS and Traction Control
Recenlty my ABS and Traction Off light have come on, I know this is on wiith same fuse as Climate Control and that and everything else is working.
The last repair on the car was lower ball joints on both sides. What might some possible causes that I can look for.
thank You
Aug 31, 2007 at 6:04 AM
GOONIOR
Have the wheel sensors checked.It sounds like they may have been damaged or not plugged back in when the lower ball joints were replaced.
BTW the ABS and the traction control use the same wheel sensors.
Sep 14, 2007 at 5:44 PM
