Le Baron fuel pump
IULIU BLAGA
  • CHRYSLER LE BARON
Le Baron 1992, 2 weels drive, auto, convertible.
How can I get to the fuel pump?
Thanks,
Iuliu
Tuesday, August 21st, 2007 AT 12:59 PM
CANADIANAPPRENTICE
  • 18 POSTS
I own a 1992 lebaron 4 dr.
You'll have to undo all connections. Do this delicately, as the connections are very fussy and tend to be very brittle. Then there are two straps that hold the fuel tank up you must remover two bolts should be 14mm but don't hold me to that. Now remove upper hoses and lines. And take the fuel tank out. Once out remove the ring around the sending unit/fuel pump. The assembly will come right out. Compare pumps to make sure they're the same and just remove and replace. Then put it all back together. WARNING** the retaining ring around the assembly may be rusty and brittle so be gentle***
good luck
Monday, August 27th, 2007 AT 8:03 PM
