1995 Chrysler Le Baron Convertible Top
1995 CHRYSLER LE BARON
59,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANDREADOPP
I replaced the top 5 years ago and it's been too tight ever since. I've left it in the sun to stretch, kept the top on for months - did everything i was supposed to do - it's still to tight. So much so, that I cannot even get the top fastened properly. Is there an easy way for me to losen the top a bit so it fastens?
Jun 11, 2009 at 5:47 AM
MERLIN2021
  • 17,250 POSTS
You probably should have had the installers re-do it correctly, as far as I know convert tops are fitted, and if fitted wrong will always be wrong...Did you ever go back to the installer?
Jun 12, 2009 at 10:16 AM
