2000 Chrysler Intrepid hard starting got code o172
2000 CHRYSLER INTREPID
MRKLEEN
Engine Performance problem
2000 Chrysler Intrepid 6 cyl Front Wheel Drive Automatic
what do I need to do to repair this problem?
Nov 29, 2009 at 1:27 AM
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode
Nov 29, 2009 at 2:38 AM
