Electrical problem
1998 Chrysler Intrepid 6 cyl Front Wheel Drive Automatic
LIGHTS AND ALL ELECTRICAL PARTS ON CAR TURNED OFF ON ME. THE CAR WON'T TURN OVER WHEN I TURN IGNITION, AND WON'T DISPLAY ANY LIGHTS ON DASH BOARD.
Saturday, September 12th, 2009 AT 10:39 PM
MECHANIC
Have you checked from the source, the battery? Also, if battery terminals and grounds to engine block are clean and tight, there is a power distribution box under the hood. If you check it, there should be a main fuse that may have blown.
Let me know what you find. Also, make sure to check the battery. It could have shorted out internally.
