2004 Chrysler Grand Voyager abs/ traction control
2004 CHRYSLER GRAND VOYAGER
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
CASSJAG
my abs light is on & my traction control wont come off is this an easy fix please?
Jan 17, 2010 at 9:44 AM
CARADIODOC
  • 34,321 POSTS
Ignore the traction control light. It is part of the ABS system. The ABS warning light is on because the computer detected a problem. You need to have a mechanic connect a scanner, (hand-held computer) to read the diagnostic fault code(s). That will lead you to the circuit with the problem.
caradiodoc
Jan 23, 2010 at 4:27 AM
