2003 Chrysler Grand Voyager replace 2003 voyager ignition l
2003 CHRYSLER GRAND VOYAGER
127,000 MILES • 4 CYL • FWD • AUTOMATIC
COMARTI7
How do I replace the ignition lock in a 2003 voyager?
Jul 18, 2008 at 10:09 AM
CLEVS
  • 5 POSTS
You need to remove the covers around the lock the under the barrel there is a little silver pin that when key is in position one it will push up and you can pull the lock out.
Aug 22, 2008 at 8:49 AM
BMRFIXIT
  • 19,053 POSTS
Removal
1.Disconnect negative battery cable.
2.Remove steering column cover retaining screws.
3.Remove parking brake release cable from handle.
4.Remove screws holding steering column shrouds and remove lower shroud.
5.Place key cylinder in RUN position. Depress lock cylinder retaining tab and remove key cylinder.
6.Remove ignition switch mounting screw with a No. 10 Torx(R) tamper proof bit.
7.Depress retaining tab and gently pry ignition switch from steering column.
8.Disconnect electrical connectors from ignition switch and remove switch.
Aug 22, 2008 at 1:23 PM
