Is the odometer working? Also, are you having any troubles with the transmission shifting? If all is ok here, most likely it is the wiring to the gauges or the instrument cluster gauges themselves are bad. If the transmission is shifting poorly it is probably a faulty vehicle speed sensor.
SPONSORED LINKS
Sunday, July 4th, 2010 AT 8:01 PM
