I heard a load pop while sitting in my car when the engine was running, the car shook and than I turned it off because I did not know what was wrong. Can someone please assist me as to what may be wrong?
Tuesday, January 13th, 2009 AT 12:25 PM
MECHANIC
Could you tell if the sound came from the front or back? Did the engine continue running?
Monday, March 16th, 2009 AT 9:23 PM
JAN914
MEMBER
Thank you for responding to my question. It sounded like it came from the front and the engine did continue to run. When I now start the car it runs hard and if I drive up a hill and press on the gas, has a hard time moving. Almost as if it is having difficulty getting into gear.
Tuesday, March 17th, 2009 AT 7:10 PM
MECHANIC
Has the check engine light come on? I wonder if it was a timing chain that jumped a tooth on the sprocket.
