1995 Chrysler Grand Voyager
ANTICS00
  • 1995 CHRYSLER GRAND VOYAGER
1995 Chrysler Grand Voyager 6 cyl Automatic
95 voyager just shuts off after an hr of driving?
Tuesday, February 9th, 2010 AT 10:19 AM
What is it doing now?
Pick your symptom:
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Compression:
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain.
No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Tuesday, February 9th, 2010 AT 4:52 PM
Related General Content
