2004 Chrysler Crossfire Bucking
2004 CHRYSLER CROSSFIRE
30,150 MILES • 6 CYL • 2WD • AUTOMATIC
TENAZ13
On occasion, once i've come to a slow or abrupt halt the engine begins to buck like its about to stall. I've taken it in to be serviced but it continues to do the same. They said filters run for much longer than other vehicles as well as the spark plugs. what are some of the possible problems that may cause this?
Thank you
Jul 15, 2008 at 4:46 AM
  • 110,244 POSTS
I'm not sure what filters you are refering to. Has the engine light come on? Also, have you checked the fuel pump pressure? It could be getting low due to a weak pump.
Here is a How To video:
https://www.2carpros.com/dia/test_fuel_pressure.htm
Let me know what you find. Also, if you need a gauge, many parts stores will rent them. If you can't find one, they sell them here at the test equipment store.
joe
Mar 16, 2009 at 9:28 AM
