1987 Chrysler Conquest
TRICHARD76
Transmission problem
1987 Chrysler Conquest 4 cyl Two Wheel Drive Manual
Just have one more question, i saw that another guy posted a problem bleeding the clutch cylinder, i just put the motor in my car and i cannot seem to bleed the clutch cylinder, i've tried all i can think of, pumping the pedal and cracking the bleeder over and over again, that didnt work, i tried putting a vacuum on the clutch and i cant get noting out of it, the master cylinder doesnt even drop a drop, i tired putting a hose on the bleed sert and put the other end in a glass of brake fluid and pump the clutch, ive been working on this for 3 days now and i have no idea what to do. i have tried the pumping the pedal and crack the bleeder and it does push out pressure but i did that for litreally hours and got nothing. if theres anything you can do i could sure use the help, thanks
Aug 8, 2010 at 12:45 PM
KHLOW2008
  • 41,812 POSTS
Hi trichard76,
No special steps or precautions are required for bleeding the clutch system.
Is the master cylinder new?
Was the hydraulic system disconnected and dried up?
Did you bleed the master cylinder first?
Is ther sufficient free play of the clutch pedal?
Aug 9, 2010 at 4:36 AM
