2000 Chrysler Concorde hearing noises in the radiator?
11,600 MILES • 6 CYL • 2WD • AUTOMATIC
KATHYW
Everytime I drive, when i shut the car down i can
hear bubbling in the front of the car. I think it
could be from the radiator although last year
i got it checked out twice and informed it
everything looked okay. the fans kick on, im
afraid of overheating. i get regular oil checks
and keep on top of the antifreeze level. what
could it be and is it still okay to drive on a daily
basis?
Sep 28, 2008 at 2:03 AM
  • 110,248 POSTS
Hi:
What I would suggest is to have the coolant checked when the vehicle is hot. If the temp is much higher than 195 to 200 degrees, something isn't working correctly. The noise you're hearing sounds like the coolant is boiling.
After you have it checked, let me know the outcome and I will explain what to do next.
Oct 7, 2008 at 6:46 AM
