1999 Chrysler Concorde Lo horn quit working
1999 CHRYSLER CONCORDE
45,000 MILES • 6 CYL • FWD • AUTOMATIC
NOONROCK
Lo horn suddenly stopped working and I haven't found the location of the horn yet. Where is it? Can this be a computer gliche or just a bad horn?
Thanks
Apr 27, 2008 at 3:04 AM
MERLIN2021
  • 17,250 POSTS
Horns are usually up front near the radiator, unplg the connector, use a test light and have someone hit the horn, does the light, light? If yes the horn is NG, if not trace the wires back to the relay...Does the other horn work?
Apr 27, 2008 at 3:14 AM
NOONROCK
[quote:f9b89900ae="merlin2021"]Horns are usually up front near the radiator, unplg the connector, use a test light and have someone hit the horn, does the light, light? If yes the horn is NG, if not trace the wires back to the relay...Does the other horn work?[/quote:f9b89900ae]
Thanks for the quick reply and here is the story as it unfolds; Hi horn works fine. Searched front end near and around radiator and can't even find access to the interior (would have to remove shroud and upper radiator support. Climbed undeneath and can't find any access beneath. Now I'm wondering if the horns are inside the wheel panel, like the battery is. Last resort is to go to the local college auto mechanics department and try to use the locater program that they have. Like the old Motors manuals only now on CD's.
Apr 27, 2008 at 4:41 AM
