I tried to restart the car. Engine turns over normally. Battery is strong. All the instrument lights go on as normal, and one by one they go off, except for the oil light. It stays on.
Changed the oil two days prior. Used a Fram PH16. When car died I checked the oil. It was full. Car was not hot.
When I changed the oil, I also detailed the engine compartment by spraying and wiping off WD-40 over everything. Could this have caused a problem? Could I have bumped something? Could the WD-40 have seeped in somewhere and caused a problem?
I swapped out the wiper relay fuse with the fuel pump relay fuse. Still did not start. I don't know if this proved anything, because I noticed the wipers still worked without the fuse in place.
Car has 105,000 miles. Has not had a timing belt replacement, or a fuel pump replacement.
Anyway, could you help? Can you think of anything I can try while the car is in my driveway? I would hate to hate to call a tow truck.
I have been successful at performing most smaller repairs on my other vehicles.
Thanks,
Jerry
SPONSORED LINKS
Thursday, December 11th, 2008 AT 12:05 PM
