2000 Chrysler Cirrus squeeling noise
SEWFINE7
Noises problem
2000 Chrysler Cirrus 4 cyl Four Wheel Drive Automatic
This car makes a squeeling noise whenever you press down on the accelarator
Sep 7, 2009 at 4:32 PM
  • 110,248 POSTS
It sounds like a belt problem. I believe there are two belts on your car. Make sure they are tight. Chances are one isn't and is causing the noise when you rev the engine because it is slipping.
Let me know what you find.
Oct 20, 2009 at 1:12 AM
