2000 Chrysler Cirrus OBD code 1776
2000 CHRYSLER CIRRUS
99,000 MILES • 6 CYL • FWD • AUTOMATIC
ILTRANSPLANT2
After changing fluid and filter, OBD code 1776 reoccurs occasionally
Jan 31, 2010 at 10:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
when you drained the tranny fluid did you see any debris in the pan? if so then tranny needs overhauled most likely. if you didn't then inspect the valve body for any damage. if OK check wiring at TCM grounds and battery feed. low battery voltage can also cause this code to appear.
Jan 31, 2010 at 12:20 PM
