1999 Chrysler Cirrus
TWIZZLER884
  • 1999 CHRYSLER CIRRUS
Steering problem
1999 Chrysler Cirrus 6 cyl Front Wheel Drive Automatic
I recently replaced the struts and strut mounting plates on my car. But for some reason when I hit a major bump I still hear a noise like metal bumping metal. Also also when I hit a bump/dip while making a turn my steering goes the opposiite direction, almost as if it has a mind of its own. What could possibly be the problem?
Wednesday, April 15th, 2009 AT 12:19 AM
DOCFIXIT
  • 18,828 POSTS
Was noise present before struts replacement? And was an alingement done?
Wednesday, April 15th, 2009 AT 4:26 PM
TWIZZLER884
Yes it made a different noise before the struts put in, also while hitting bumps at high speeds.
Wednesday, April 15th, 2009 AT 7:06 PM
DOCFIXIT
  • 18,828 POSTS
Check out the lower control arm bushings. You did not indicate milage if 100k + a possability
Wednesday, April 15th, 2009 AT 7:12 PM
TWIZZLER884
Oh ok. I'll have that looked at. Thanks. The mileage is about 185,000
Wednesday, April 15th, 2009 AT 8:53 PM
